Old 03-12-2014, 09:30 AM   #19
tomonomics
>>yes but the 03-04's were also the heaviest 986's. And the power bump was not huge.<<
From the online specs, they are only 66 lbs heavier with 8 more HP. Which 'technically' is a better power/weight ratio. Not sure what common options might sway those numbers.
I thought the improved vario-cam performance improved low-RPM response as well. Am I missing something that would make the 2000 S a better performer than the 2003 S?
tomonomics is offline   Reply With Quote
