Motiv Black Label European Power bleeder
air compressor - about 5 cfm@90psi, 15 gallon tank min.
Uview Airlift Vacuum tool
Good torque wrenches - 40 - 250 in-lb, 5 -75 ft-lb, 50 - 200 ft-lb (Snap-On if you can)
remote hose clamp tool, rad hose picks
16mm security triple square bit
very good quality metric flare wrenches - the cheap ones spread under load and fu your fittings. Go with Mac, Snap-On, Craftsman
That should get you started
'99 black 986
