Originally Posted by dghii
If you are getting any sort of signal, I'd say your amp is most likely ok.
Easy stuff to troubleshoot.
1. Remove both speakers and swap. This step will isolate either a bad speaker or bad signal coming to the speaker. Inspect each speaker for a worn out foam surround. Don't be surprised if the foam is mostly missing.
This is a good time to buy new dash speakers! You'll be plesantly surprised what a difference new aftermarket speakers will make. Best thing is, you can find good choices for $35 and up! I updated mine with Polk speakers from Crutchfield last winter ($40 incl. shipping). They sound so much better than stock.
yes, I think it's time to upgrade!!
any recommendations on the dash speakers with minimal alterations to the mounting ring?
