Old 03-10-2014, 08:31 PM   #326
Nine8Six
Nine8Six's Avatar
Looks great!
Would LOVE to install those alu retrofit projectors in seal gray + amber,
... BUT sadly I would never pass a German TÜV-inspection with such an undoubtfully great, but "unlicensed non-OEM-DIY" solution" :ah:
Of course you would.
Given you go for the factory 4,3k color temp bulb only (no bleu, purple fancy stuff for ya I'm afraid)
It's a "technical" inspection, nothing personal or feelings attached with the various part manufacturers of what your car is made of - which is a lot. Below is what germany regulates officially only. Although I wouldn't be surprised they ask you to remove the chrome frame covering your indicator :/
· Headlight alignment- Aim of a headlight not within limits prescribed in regulations. Lamp color, position, or intensity not in accordance with regulations. Headlight height less than 56 centimeters or higher than 137 centimeters.
· Incorrect turn signals- Light color, position, or intensity not according to regulations.
and don't forget your medic kit. That also will prevent you from buying gas if you don't pass your tuv
