Old 03-10-2014, 09:36 AM   #2
JFP in PA
These cars should not be overfilled, do so can lead to problems ranging from smoking, to seal leaks, and AOS failure. As you just had your oil changed, let the car sit for at least and hour or two, then switch the key (don't start the car) and check the oil level. If all the bars are lit, you need to drain some oil out of the car.
