Old 03-07-2014, 03:30 PM   #2
Timco
I am my own mechanic....
Timco's Avatar
Can you get the car moving on flat land with no gas ? You may be over-reving the engine and burning clutch. You may need to over-rev if you have some idle problem. It should not die after startup, but drop to perfect rock solid idle. If it stalls after it drops, check / clean throttle body, check plugs. No CEL?
'08 VW Touareg T-3 wife's car
