					Originally Posted by Lobo1186  It is hard because you want a case that will fit your stuff but alot of cases are really long which means it will not fit in the Boxster. (Except in the passenger seat which is not preferred.) So this one is a little wider and less long so it will fit in the rear trunk.
So it is fairly large but not so large it will not fit in the trunk   |
Fun fact, the 986 trunk was specifically designed to be able to fit a set of golf clubs.  Also, the frunk was designed for this:
