Originally Posted by keithl
Thanks!
It actually does come on with the other lights. Will there be codes there even if the CEL isn't on? Does it sound like a flakey fuel pump if the CEL isn't coming on?
Was this resolved? I'm having a very similar issue with a 987.
I will shift (downshift or upshift, doesn't matter), and once in the new gear the car acts like the gas pedal isn't even connected. Like tonight at a green light I had it in first and it started moving then it acted like the gas pedal wasn't even connected, so I shifted to 2nd and it acted normal again. Seems shifting fixes it, but I don't want to always have to shift, it should have power in the gear I'm in. Happened in 5th too, I even floored it and pumped the peddle, just acted like the gas pedal was connected to nothing but I could hear the peddle hit the floor, but as soon as I shifted to 4th it behaved normal again.
