Originally Posted by eli cash
On the way home after filling up, I noticed the oil reader was abnormally low. I changed the oil only a few months ago. I also had been driving for several minutes right before this happened.
The engine oil level gauge will always read less than max full under these conditions. A fuel fillup does not provide enough time for all the oil to drain back into the sump. Also, you may not be on a completely level surface when the reading is displayed.
As long as the level indicated is between the min and max arrows on the gauge, you are fine. To get an accurate reading, check the oil level when the car has sat for a few hours on a level surface.
Originally Posted by RandallNeighbour
I have noticed that my car does not need 9.5 quarts of fresh oil, even with a filter change.
My owner's manual calls for 8.7 quarts which is my benchmark. After driving and setting for a few hours, I may have to add an ounce or so.
Definitely do not overfill. If you do, pump or drain out the excess.
Just sayin'.......
TO
