Like any car, you should expect oil levels (gauge or dip stick) to indicate low if you check immediately after running the engine. The oil is circulated out of the sump. If you try and top off at that point, you will most likely Overfill. As stated before, check cold and level and rely on the Dip Stick if you have one.
Seal Grey
