Old 03-04-2014, 08:50 AM   #309
Nine8Six
Nine8Six's Avatar
Hey Particle,
How do you get the corner triangles off?
The little tabs broke off when I tried to remove one.
Worst case scenario is I just have to epoxy the triangle in place without the tabs I suppose.
I also wonder if there is any aligning of the lights necessary after installing the Projectors?
Hi Ray, hope all is going fine there for you mate. Sorry to hear about the broken corner.
Re aiming your headlight, have a go at HOW TO: aim HID headlights and look at the various methods the guys use. The common 25' away from wall method is the one I use and recommend (flawless). This is all done using the Porsche headlight adj hex tool - nothing change there
