Old 03-03-2014, 10:47 PM   #1
scottvd
scottvd's Avatar
I own a screaming rag top
Depending on headwind from circa 85-95 MPH my rag top sounds like it's screaming just on the passenger side of the center latch. I figured wind was getting past the seal and causing a whistle sound, so I used einszett 'Gummi Pflege Stift' Rubber Care Stick on the weather seals but that didn't seem to do the trick.
Any ideas on this, can the tension be adjusted on the center locking latch? Both sides are locking into position as designed - there are no other problems with the roof besides this. Thanks.
Scott
2004 Boxster S
scottvd is offline   Reply With Quote
