Old 03-01-2014, 11:07 PM   #11
particlewave
Hey Particle,
How do you get the corner triangles off?
The little tabs broke off when I tried to remove one.
Worst case scenario is I just have to epoxy the triangle in place without the tabs I suppose.
I also wonder if there is any aligning of the lights necessary after installing the Projectors?
Yes, some alignment will be necessary, but if your lights were aligned properly before the retrofit, it will be minimal.
To remove the corners, carefully pry the clips back just far enough to push the top of the trim piece out until the pins are clear of the headlight housing, then slide down
Unfortunately, the older they are, the more brittle they get. It doesn't hurt to hit the backside clips with a low temp hair dryer or heat gun for 10-15 seconds to make the plastic more pliable.
