Thread: Hard top
Old 02-28-2014, 05:58 PM   #13
wawa
as it was said, its a easy job. Some will tell you to use plastic pelicule to hold the bolt and try fitting it tru small openning. Forget that, you will lose time, patient and maybe the bolt lol. Simply remove the carpeting panel as stated, very easy, and now you have much more space and way much easyier to bolt the spin lock.
20 min job and both side are done. You are then ready to pick up the top and fit it on. Very easy. I even put it by myself once. Will not do it again!! very risky to scrach paint. But to person is very easy.
good luck
later all
wawa
wawa is offline   Reply With Quote
