Old 02-27-2014, 01:41 PM   #2
BYprodriver
BYprodriver's Avatar
Originally Posted by jdraupp View Post
It's more the road force tire balancing I'm after. I'm pretty sure the stick on weights on my tires are gone as I get a semi noticeable shimmy at higher speeds on flat slabs of road. Tire Balancing was the biggest suggestion for this issue, especially on the Hunter Road Force.
If the weights are gone anyplace with a wheel balancer can remedy that & alignment will have no effect at all. Make sure your front tire are set for 29psi @ 70 degrees & 35psi in the rear. If the car is new to you check the dates on the tires, if older than 4 years that could be a contributer to the issue.
