Old 02-25-2014, 04:24 PM   #11
LAP1DOUG
LAP1DOUG's Avatar
Originally Posted by 993innc View Post
To recap, I've installed H&R coil overs front and rear (no spring rates from H&R other than progressive). I installed the LCA's with 13mm worth of shims each side, and am running 25 1/8"- 25 1/4" ride height to fender(center of hub) all the way around.
At that ride height, you may find that your LCA's are "over center", which you obviously know is not optimum.
Good luck.
Kippis
986S
991S
Van Diemen RF97
LAP1DOUG is offline   Reply With Quote
