Best case scenario: Some fuses, diodes, and relays are blown.
Worst case: The above, plus the alternator is toast, maybe the voltage regulator. You might have some warning lights, and the gauges may not work properly.
In your case, I'd have a professional look at it. The car should start with the battery installed correctly, but I'd check with the professional first.
TO
