Old 02-24-2014, 05:14 PM   #10
LAP1DOUG
LAP1DOUG's Avatar
Does anybody unmount the fronts (and/or rears) and move them to the other side to gain some extra life out of the tire? I guess that wouldn't for tires that have an asymmetric "inside" and "outside" tread, but if you had a symmetric tread (and/or directional? a quick check of Tire rack shows that all of the Extreme summer performance tires are either asymmetric or directional) then could you swap them side-to-side? Or does the expense of making such a swap negate any extended usage received.
Does anyone do this?
Thanks,
Steve
Some people "flip" tires to even the wear. This can be done with symetrical tires like a R888 or a ZII, but not with an asymmetrical tire like an NT-01. As I understand, it involves unmounting the tires, and flipping them on the same wheel, but I have never done this. I guess the economics depend on your cost of labor at the tire shop vs. cost of the tires you are flipping. If you modify to achieve proper camber, there is no reason to do this.
Kippis
986S
991S
Van Diemen RF97
LAP1DOUG is offline   Reply With Quote
