In your first post, you state that you have only had the car for four months. Seeing that there is still paint on the pulley surface, I would think that it is more than likely a new pulley, otherwise all the paint would have been worn off by now. Sounds like the previous owner had a problem and replaced the pulley with a new one. Might have over tightened the bolt and lead to the failure. A lot of people think they have to tighten every bolt as tight as they can.
