Old 02-19-2014, 03:05 PM   #25
Dave2001S
Appreciate the feed back, thank you. One question about the decals: the instructions said to wet the caliper surface and the front/back of the decal itself with a dilute hand soap and water solution. Then, use a small squeegee (that wasn't supplied) to press out the underlying water and position the decal. Did you guys follow this procedure? I'm hoping the cloudiness will dissipate over time; otherwise I'm going to peel them off and do a stencil. Final note, the G2 kit specifically says not to use a spray on clear coat as it could be incompatible with the epoxy based paint, so I didn't. I'm now questioning that directive as well. In the end, I'm sure they will be fine and look nice.
Dave2001S is offline   Reply With Quote
