Old 02-19-2014, 10:37 AM   #23
Mark_T
I used the decals and they look fine, no outline or adhesive showing, BUT, I spray painted the calipers with VHT, let them cure for a couple of days, then applied the decals and let them dry for a couple of days, and then applied a few coats of clear VHT. I thought they turned out really well.
I read enough reviews of the G2 stuff ahead of time that I was pretty sure that brush strokes were going to be a problem, which is why I didn't go that route.
So, now you've done the prep, you could wet sand the calipers to get a flat color with no brush strokes, re-apply fresh decals, spray on some clear coat, and you would most likely be happy with the end result.
'99 black 986
