Old 02-18-2014, 01:26 AM   #20
uladzislau
The old oil fill tube was broken in half, installed a new one today but could not get it all the way to the oil filler pipe at the engine side. I read that you can break the pipe that goes to the engine easily and the it's total pain to change it out so I don't want to use excessive force. It stays put just fine and the clamp is holding it in place.
The old broke old fill tube, I think it's the original '97 one .
The new tube is not 100% fit onto the oil fill pipe.
I'll see in a few days if it cured the RPM problem because I was basically driving without the oil cap . Also I'm wondering is my AOS is not good, the cracked oil filler tube is one of the symptoms of a bad AOS. After I've put the new tube I still can remove the oil fill cap but now the it has considerable higher level of vacuum and the engine dies almost instantly after the cap is removed (cold engine).
uladzislau is offline   Reply With Quote
