Old 02-17-2014, 05:12 PM   #7
healthservices
Registered Boxster abuser
healthservices's Avatar
Basically the tie rod ends and the ball joints are sealed. if they dry up you can poke a pin hole in the dust boot to squirt some wd40 in. The WD40 is a temp fix and just used as a diagnoses tool. If the squeak goes away or changes, replace that arm or joint.
