The kit cost is going to depend on what you replace.  With the Boxster, I'd recommend the full change (clutch disc, flex plate, release bearing, pilot bearing) minimum and also look at the flywheel since it is sometimes a source of vibration.  If you don't do the full meal deal, it will end up costing you more when they have to pull the whole tranny to replace a $12 bearing.
