Old 02-16-2014, 08:54 AM   #13
JFP in PA
Originally Posted by Jamesp View Post
Thanks for your reply JFP. I used time instead of a gauge. If the system holds a low vacuum for a full 30 seconds my sense is any leak is less than a pinhole. I think I'll go check it for a full minute though. I did listen for a hiss as well and did not hear one. I bought a plastic vacuum pump similar to the one you show to bleed the clutch as it was marketed for use in brake jobs. It would have been a better tool if it was compatible with brake fluid.
I don't care for vacuum brake bleeding tools at all, I prefer the pressure style like the Motive system because it pushes clean fluid downward and through the system without any chance of pulling air in, which a vacuum system can quickly do.
