Old 02-15-2014, 07:48 PM   #15
Jamesp
Beginner
Jamesp's Avatar
Originally Posted by Reebuck1 View Post
Space cowboy, Did you throw any error codes when you finally installed the motor in your car and got it running? \
My car is throwing some codes - one was a bad precat O2 sensor so I swapped them and sure enough it popped up again in its new home so I replaced it, no issue there (Thanks to advice from this forum). Now I have two additional codes, P0171 and P0174, bank 1 and bank 2 too lean. There are several possible reasons for the two codes, most likely is a vacuum leak and I'm chasing that down.
The cam timing error after an IMS bearing install you have is in a whole different league. It makes me think the valve timing has slipped, i.e the cam chain is a tooth off. If it were me I would not run the engine anymore. I'd pin the engine at TDC and check the valve timing with a timing tool. Either it is correct and you can move on to something else or re-adjust it and you are done. Otherwise you risk valve/piston interference which is catastrophic.
2003 S manual
