Originally Posted by The Radium King
check the boot that holds the resonance tube in place - it mught be cracked or folded somehow underneath. when you have the resonance tube off check the secondary air injection system - it has a couple of vacuum connections in that area.
Done. Everything looked good. Tried to blow through the spagetti tubing and all the valves must be closed because there was no airflow. Is it common for the air injection cut off valve or the vacuum reservoir to leak? Could that be the source of the vacuum leak?
