Old 02-14-2014, 07:46 PM   #1
The Radium King
The Radium King's Avatar
the fuel pressure regulator is just underneath and has a vacuum connection. there is an aos connection down there as well. the brake booster line is easily worked on from under the car (easy being a relative term wrt the boxster). best test would probably be to disconnect the booster at the manifold, plug the opening in the manifold, and see if you still have a leak.
