Old 02-14-2014, 09:04 AM   #3
BYprodriver
BYprodriver's Avatar
Guessing your fuel pump has died. The fuel rail has a schrader valve on it. Remove the cap & press the valve to release some pressure & fuel. If no fuel is present the pump has probably died. When you run the tank low on fuel the pump can overheat.
