					Originally Posted by dghii  Nice job.  When you tapped into the stock speaker wiring did you tap into the wires or cut and splice. |
I used wiring harness' so I could put the factory one back in if I sell the car.  Never had any issues with noise.
					Originally Posted by BruceH  What amps did you end up with? |
I used an Alpine MRV-M500 mono block amp for the sub as the JL 10tw3-d4 is a dual 4ohm and it's stable at 2ohms mono.  Used an Alpine MRV-F300 4 channel amp for the dash/door speakers.  The Alpine CDE-HD149BT head unit I used has time correction so I wanted dedicated channels for each of the speakers.  Works well as I like the sound stage high and not too wide.
