Old 02-13-2014, 08:04 AM   #10
dghii
There are only lower control arms on the Boxsters.
The control arms are expensive relative to other suspension components.
What's the year/mileage of your car?
You might want to check out your drop links and sway bar bushings first, as new drop links are about $50 each and bushings are cheap.
Rebuilt track arms available for $150/ea from another vendor. Worn track arms make noise over small imperfections in the road or parking lot and are most annoying at low speeds.
Clunking can be a result of a worn strut bearing or mount. The bearing is about $50/side but you have to remove the entire strut assembly to replace, hence it may be time to replace the strut as well (~$250each).
Suspension stuff gets expensive fast!
