To do a complete job of the brake bleed you should also bleed the clutch as well, otherwise you still have old fluid in the system due to the shared reservoir.
I will echo what others have said about the value of the Motive Black Label European Power Bleeder. Absolutely worth every penny, especially for the clutch portion of the bleed.
Seized nipples sounds painful. I'll definitely try to avoid that.
'99 black 986
