Schroth makes belts specifically for GT3 seats, or they will modify another of their belts to add the quick release clips you need. BK makes the mounts you may need to get low enough for your helmet not to stick out. You'll still need a bolt-on harness bar to mount the shoulder belts; most race shops can make these quite quickly and cheaply. The lap belt mounting points are OEM. If your seat doesn't have a cross bar for the under-mount belts, BK makes one of those, too. Stable Energies of NJ set mine up.
