Originally Posted by Timco
Still think heat shields. I pushed on the muffler heat shield and just changed its shape slightly and fixed a rattle. If you whack the exhaust / pipes with your palm, no rattle? Do the same with the trunk bottom. See if HS is touching trunk bottom.
i just changed to a fabspeed exhaust .. and took the opportunity to wiggle & wack everything i can see .... using a wrench ... tried to clank on this to replicate the sound .... the cat heat shield solid as a rock .. not fouling anything.
..... really drives me nuts
