Glad to hear that everyone is satisified with the Solution. I have a Solution install scheduled next month.
The only two (probably dumb) questions that I have over the new "Double Row Pro" are:
1. "IF," and I know that it is a big IF, the oil line from the filter to the plain bearing should be severed, what would be the result? Would you know soon enough from the oil pressure gauge in the car (would it drop instantly to 0?) to swiftly turn off the engine or would that not work since you are taking a small amount of oil from the filter adapter and the pressure would not be affected?
Is there any application where the Double Row Pro could be a better choice?
2. Once you go IMS Solution, can you ever go back to a bearing? (not sure you would ever want to do that)...
