Originally Posted by Edreamsz
Guys, can you use Plastx to remove a light scratch on the inside of the lens? I have a small "smear" of light scratches on the inside.
Cheers
Hubert, you certainly can however not recommended. If you go ahead think about surgically clean microfiber cloth when doing so. There are no scratch (& UV) protective film on the inside part of the lens therefore any hard-dust on your cloth will make it worst (scratch the lens).
Polishing (finishing) will need to be done using a "camera lens polishing cloth'. Doable but again, got to be done in a very clean environment.
