Old 02-09-2014, 06:53 PM   #1
drbodzin
San Diego Boxster
drbodzin's Avatar
Question Questions about boost gauge reading - advice?
Today, I fired up my car for the first time since installing a supercharger.
Installing Imagine Automotive Super Charger on my 1998 2.5 Boxster
Here is a sample images of the gauge.
The Boost Gauge is reading Vacuum when at idle. I assume that's normal. When I increase the RPM, I do see the boost gauge increase the boost (REDUCE the vacuum), but its still in the vacuum range of the gauge. It's like there's less vacuum.
Does that seem normal for a supercharged engine?
I was thinking I should see the gauge in the boost range, not still in the vacuum range.
Am I correct to assume that without the supercharger, there would be MORE vacuum with increased RPM?
The boost sensor is installed with a "T" connection into the vacuum line the goes into the intake manifold after the throttle body (per the instructions).
Any ideas?
Happy Boxstering!
Miles
1998 Black Boxster (owned since 2001)
drbodzin is offline   Reply With Quote
