Old 02-09-2014, 08:07 AM   #2
Brian0icu812
Just tried the micro switch. 1 holding it down... nothing, and then i used a wire to jump the two posts and still nothing so this seems to be good.
So Summary:
- Doesnt start, no click or noise what so ever, all interior/dash lights work fine
- If the starter is jumped it will attempt to start but wont fire (acts like dosent get gas)
- Ruled out ignition switch (mechanical and electrical), battery and clutch microswitch
Possibilities:
Immobilizer, key?, ground wire? (although i checked all the ones i could find),
Prior to problem:
-Engine was replaced, then worked fine for a few weeks after new engine was put in(started first time everytime)
-Ignition mechanical switch was bad, wouldnt spring back after started
-Before the engine replacement everything worked as should with the starter just didnt fire
My guess would be the clutch switch. This happened to me once and it was just the floor mat stuck under the pedal.
Brian0icu812 is offline   Reply With Quote
