I did close the top from the service position before it quit starting but i then tried it with it back in the service position, up down and all positions out of desperation but still no click or noise from the starter.
Also this may help, when it was starting it had a bad mechanical ignition switch and didnt spring back once started so the starter was still engaged while it was running. Would this of fried a relay? It was never running more than 5 minutes.
Tomorrow morning i will bridge the clutch micro switch to see if thats the problem. Does anyone have a relay diagram so i can check the starter relay
