Old 02-08-2014, 06:37 PM   #1
Brian0icu812
Yes correct it only turns over when jumped
Yes i hear a humming when the key is to the ignition on selection
and I dont have a clutch interlock as the wrecked one was triptronic
Other thought: it seems like a anti theft or kill switch b/c everything worked (approx 10 starts over 2 weeks) and did nothing different or changed anything to make it not start. Everything seems correct except it does not turn over. I have to double check the fuel pump though as the humming noise could be something else.
Originally Posted by woodsman View Post
Can you change the clutch interlock with another?
Often the first think to let us down is the last thing we fixed. IE- a loose ground or other wire/ connector.
Brian0icu812 is offline   Reply With Quote
