So the starter turns when 'jumped' but not when you turn the key?
Fuel pump- you should hear it start after turning key on and there's a Schrader valve fitting on the right fuel rail for a pressure tester.
The main DME relay is in the trunk and I think this can cause 'silence' with key-on.
