Old 02-07-2014, 09:17 AM   #10
Deserion
Multi-Boxer Driver
Deserion's Avatar
"Entry and Drive" is a keyless function. Touch the door handle to lock/unlock when the remote is in your pocket.
Per Porsche
With the optional Porsche Entry & Drive, you can leave your car key in your pocket. As soon as you grab the door handle or approach the luggage compartment, the system automatically checks the encrypted access code on the key. Once the key is validated, the door or the luggage compartment lid unlocks. The engine can then be started and switched off using the electronic ignition switch.
To lock the vehicle, you simply press the button on the outside of the door handle. Porsche Entry & Drive then locks the vehicle and activates the engine immobilizer and steering column lock.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
