Old 02-05-2014, 03:21 PM   #1
pothole
not something you should even try. Fuel pumps, like all the other over-priced Porsche parts, are expensive. That's a $1,000 job you don't need to speed up by running your fuel that low.
Right up to the point the fuel pump burns up for lack of cooling from the lack or surrounding fuel; bad idea.............
I run my down to fumes routinely, to the point where the OBC stops displaying the range and the needle is below zero - most tanks for the last 50,000 miles (now on over 120,000) and I rarely even put half a tank in, so it happens a lot. Needless to say, haven't had any problems.
Not saying it couldn't cause a problem. But based on doing it over and over and over and not having a problem, I would suggest occasionally running it down is a total non issue.
pothole is offline   Reply With Quote
