			Details of the rebuild:Everything touched was cleaned and repainted as necessary
 Heads sent out .010 out of flat corrected, new seals installed, valve job
 All timing chains replaced
 Chain ramps replaced
 Main Bearings replaced
 Thrust bearings replaced
 Rod bearings replaced
 Clutch disc replaced
 Clutch pivot in transmission replaced
 Engine seals replaced
 Air oil separator replaced
 Pistons and rings cleaned.  Original piston rings reused
 Plastic balance tube replaced
 Intermediate shaft replaced with a modified IMS to reduce the chance of IMSB failure
 Pelican parts IMS bolt/sealing parts used
 Nachi high temp Viton sealed IMS bearing installed
 New connecting rod bolts
 New front motor mount
 Non engine items:
 New horns
 Both window regulators fixed with the bicycle cable adjuster trick
 Birds nests and other trash deleted from the front radiators
 Broken plastic tabs on the rear wing plastic cover glued with epoxy and plastic cover re-installed
 Headlights polished to remove yellow haze
 Car detailed
				__________________2003 S manual
