Old 02-03-2014, 05:21 PM   #10
rionhosaki
I contacted K-sport and they refused to give me a 5.3 spring.
"Regarding spring rates, they advised that a 5.3kg up front isn't doable as they don't offer any springs in this design with that rate. "
"They did mention that is only a very small difference from the 6kg that the kit comes with. Regarding the rear, they said they could do the 7.5kg rather than the 8.7 if you'd like. They did warn that the warranty on the struts portion of the coilovers would be voided due to this. They advised that they spring rates offered on this kit were chosen for a specific reason and that by going softer on the spring rate, you do risk possibly damaging the struts that are included. If you'd like to proceed, it is an extra $12 per corner to change to a different spring rate. "
Should I go with 6kg front and 7.5kg rear? and void the warranty or go with the 8.7 rear?
i don't want the ride so rough that my teeth gets rattled out or destroy my wheels.
rionhosaki is offline   Reply With Quote
