Old 02-03-2014, 10:26 AM   #13
uladzislau
The cracked oil filler tube is a common problem... And a pain to change out too.
I hope you figure out your problem. Sounds like you've discovered others along the way...
I've got the new tube and tools for taking the spring loaded clamps. I read that it's PITA to change but will have to anyway. Better to find and fix it sooner than later ;-). Thanks for follow up and all the suggestions guys! The new idle control valve is on its way, I'll install it hopefully tomorrow or day after and will let you know.
uladzislau is offline   Reply With Quote
