Old 02-02-2014, 08:35 AM   #232
chipmunk
chipmunk's Avatar
Originally Posted by jdlmodelt View Post
Excellent comparisons. I liked the throaty sound at 25mm. However, from some of your newer posts, you indicate 25mm is too much volume.
No, the volume is fine - not loud, more like a background purr that you can hear through the rev range. When you open it up it's almost a little disappointing as you don't get the corresponding increase in exhaust note - primary because the higher the engine speed, the more exhaust gas passes along the original route, rather than out the drilled holes.
My only concern was the introduction of a little drone at 2800rpm - nothing like aftermarket exhaust however something to consider. On the flip side, the exhaust sounds like you would expect a sports car to sound.
I will put together a "driving video" when the weather warms up a little. It's a bit too cold at the moment to put the roof down!
2003 Boxster S
chipmunk is offline   Reply With Quote
