Old 02-01-2014, 07:44 PM   #1
Jamesp
Beginner
Jamesp's Avatar
Originally Posted by The French Dude View Post
Jamesp are you sure that Boxster have timing belt? Is it not rather a timing chain?
I wish I were multilingual, but alas, my talents fall far short of that. So my hat is off to you for communicating in two languages. My post said, "It is analogous to a timing belt... " Analogous means parallel or similar to, but not the same. The point to be made is that if a timing belt fails, notoriously on older Honda engines, the valves and pistons may clash resulting in severe engine damage. The IMS bearing is similar to this in that if it fails, the same thing happens, and much like the Honda timing belts, the manufacture does not recommend replacement, Though in Honda's defense, they eventually did.
2003 S manual
