Old 01-30-2014, 10:36 AM   #266
particlewave
Originally Posted by Edreamsz View Post
I am finally converting the headlights for my Black Boxster. Will post pics soon! I do have one question: What is the best way to secure the ballast inside the headlight unit? Please post a pic so I can better understand and see how it was done.
Thanks!
I wouldn't recommend mounting the ballast inside the headlight as this can cause it to overheat. This is how I mounted mine...I got a little sloppy with the hot glue where the wires pass through the rear cover until I found a better fitting grommet
Mounting it in this way allows for superior cooling (just like the Litronics) and doesn't interfere with normal headlight installation.
