Old 01-29-2014, 04:59 PM   #4
sb01box
Originally Posted by Dave S. View Post
I don't think it makes any difference where you put it in the system. I put it on the front lower pulley behind the speaker where it was easiest to access. I also added some wireties to create additional tension at the spring adjuster coming out of the bottom of the motor.
if you put the additional spacer anywhere other than between the motor and immediate pulleys on either end you will disrupt the front to back tilt/level of the window and will require additional alignment.
sb01box is offline   Reply With Quote
